gardengirl38
I went back and read everything I could find on O2 sensors under this forum.
I got a check engine light and the code read P0133 Ckt O2 Sensor slow to respond Bank 1 Sensor 1.
SO I thought I would replace it since its 21.99, here is where I run into a snag. At Auto Zone there are four sensors and they do not call them 1,2 1,2 or left, right etc... The description says rear upstream sensor rear downstream sensor and front upstream sensor front downstream sensor. SO when I look into my jeep from the drivers side of the engine I can see two sensors that are side by side, and further down which I believe is after the catalytic converter I can spot one, I havnt searched hard for the other yet... but when I look at the first two up top is that upstream and how do I know which one is which as far as which would be the front upstream and which would be the rear upstream... what the heck... this is frustrating. I need a diagram. I have tried to order a Haynes manual for my Jeep with no luck yet. Anyway I want to learn this stuff but have searched the web and just hear conflicting information. Some posts say I dont have four sensors, some say I do... Some say if my Jeep was made for California I have 4 but if not I have 2... I want to know what the heck to replace haha. Seriously, I have almost 100k on the jeep and thats the recommended check/replace schedule on the sensors. And should I rent the tool for doing this? Thanks for any thoughts...
