YJ FAQ write ups
K_K_PSI_GUY
Found this on another board. Good info.
This thread is for a quick reference to links that users have come across in their journeys across the interweb. If you come across a YJ tech article feel free to add it to this thread. Please, if you have one post, just modify your post as you find more.
Please make your post like below. Anthing that diviates (chit chat) will be deleted. Please keep your post like below and I hope this is usefull.
Thanks.
Sample:
http://www.riptech.net - A site with a package that you can purchase to make the wiper go down like on TJs.
Here the list starts.
http://www.jeeptech.com/models/yj.htm - Basic stats on YJs
http://www.off-road.com/jeep/tech/convaxle/ihscout/ - Swapping Dana 44s and a Dana 300 into a YJ
http://www.off-road.com/jeep/tech/susp/yjsh.html - Wrangler YJ Travel Trick
http://www.off-road.com/jeep/tech/susp/ubolt.html - Flip Your U-Bolts
http://www.off-road.com/jeep/swb/articles/dash.htm - Swapping a CJ dash into a YJ.
http://www.offroadexchange.com/yjbdylft.htm - Installing OME 2.5 Lift.
http://www.sierrajeep.com/moparmpi.htm - Mopar MPI Injection Installation in a YJ
http://www.jedi.com/obiwan/jeep/soa.html - Spring-Over-Axle Conversion for a YJ
Added 01.22.03
http://www.stu-offroad.com - Great site, has mutiple write including a 8.8 swap. http://www.yankeetoys.org/mangler/88swap.htm - Another good 8.8 write up.
Added 01.24.02
http://www.rockcrawler.com/techreports/reyj25lift/index.htm - Step by step install of a RE 2.5 lift kit.
http://www.rockcrawler.com/techreports/reyjextreme/index.htm - A review of the RE 4.5 lift with, before during and after pics.
http://www.4x44u.com/pub/k2/am4x44u/installs/MetalWard - MetalWard's YJ Extreme Bumper System, with installation guide.
http://jedi.com/obiwan/jeep/soa.html - Spring-Over-Axle Conversion on a '95 YJ
http://jedi.com/obiwan/jeep/15to20gal.html - YJ 15-to-20 Gallon Gas Tank Conversion
http://jedi.com/obiwan/jeep/yorkair.html - York Compressor for On-Board Air
http://jedi.com/obiwan/jeep/throttle.html - Hand-Operated Throttle Control Lever
http://jedi.com/obiwan/jeep/welder.html - Premier Power Welder Install
http://jedi.com/obiwan/jeep/quickdisco.html - Custom Sway Bar Quick Disconnects on a '95 YJ.
http://jedi.com/obiwan/jeep/hoodbump.html - Hood Bumpers
http://jedi.com/obiwan/jeep/flattow.html - Flat Towing a Jeep Wrangler: Tow Bar Brackets and Trailer Light Wiring.
http://jedi.com/obiwan/jeep/d30axleseal.html - Dana 30 Axle Seal Replacement in a '95 Wrangler.
http://jedi.com/obiwan/jeep/exhaust.html - Installing a new stainless steel exhaust on a '95 Jeep Wrangler (YJ).
Added 1.30.03
http://www.bc4x4.com/tech/2001/tjflares/ - Putting TJ flairs on a YJ
I feel very fortunate that Obiwan (jedi.com) is in the Jeep club I belong to... That guy is a WEALTH of information and his no fluff-maximum information website is a boon to Jeepers everywhere...
thank you for the compilation.. this thread might make a good sticky... as a reference
Wow this is a world of help... Too bad im still pulling my hair out on this stupid electrical on my 4cyl auto YJ conversion to a 6cyl stick TJ... never knew 30 wires could be such a pain in my rear to trace... connect.. and mate with two wire harnesses.
Kletus
