Are you just replacing the U-bolts or are you replacing the entire yoke? Are they snapping off, or do they appear to be wearing out? Have you thought about having your drive shaft re-balanced? if you are only replacing the U-bolts, it may be that the yoke itself has some "slop" in it, and thus it is wearing out the pieces? Worst case you could run it to a transmission shop and let them replace the parts...that way it is under "warranty" with them...with the 3" lift it shouldn't have changed the angle of the shaft to much, but that is a possibility...
