Latest activity
  • superj
    superj reacted to Engir's post in the thread Fuel Gauge issue with Like Like.
    The pump comes on when you turn the key to the ON position and I can hear it run until it builds up pressure then stops which could have...
  • TerryMason
    TerryMason replied to the thread Weird engine noise from my TJ.
    OK, that really does sound like monkeys - I can't unhear it now. Thanks for that video - his does sound like mine, and the fact that it...
  • Engir
    Engir replied to the thread Fuel Gauge issue.
  • superj
    superj replied to the thread Fuel Gauge issue.
    No, you can easily do that but its only going to come on for about a few seconds when the engine cranks and then it will stop. But...
  • JPNinPA
    JPNinPA replied to the thread Weird engine noise from my TJ.
    Laughing monkeys!!! OPDA https://youtu.be/HVjwVkLahw0?si=atsnhS_DGT1M66D2 He skips quickly through important part. Take engine to...
  • Engir
    I went on Amazon a short time ago and purchased another fuel pump assembly from it is a CARTER it should be here in two weeks. Is there...
  • Engir
    So, you do not think it is the relay or fuse? I have been trying to find out what wire does what on the body harness but have not found...
  • superj
    superj replied to the thread Weird engine noise from my TJ.
    I was going to say to taje the belt off too
  • superj
    superj reacted to Jeepergeo's post in the thread Weird engine noise from my TJ with Like Like.
    Take off the serpentinr belt. Run the Jeep and see if the noise goes away. If it does, it is one of the belt driven components.
  • superj
    On the three wires from the body, do you know which is power to the oump and which is ground? I imagine black and red? Unplug the pin...
  • superj
    superj reacted to mark sr's post in the thread Accident Woes with Like Like.
    Did you discuss the paint sag with them? Personally that sag would bug me every time I used the jeep since it's on the driver's side.
  • TerryMason
    It's an auto. The weird thing is that the noise only happened that one trip. After I turned the jeep off and restarted later it was...
  • J
    Jeepergeo replied to the thread Weird engine noise from my TJ.
  • ndnatty
    ndnatty replied to the thread Weird engine noise from my TJ.
    That is a strange noise. Automatic or manual? Flywheel related? Will be interested to know what causes it. Good luck! Sent from my...
  • TerryMason
    Hopped in my 2005 4.0L TJ and drove halfway down the street before I noticed a weird noise. It was engine speed related, and would...
