Latest activity
  • TerryMason
    I've ordered new rubber mounts, that should be hear in a couple of days, along with my new shroud. I'll probably try to lower the...
  • J
    Jeepergeo reacted to eric m's post in the thread You might be a redneck if ........ with Like Like.
    ...if your too long glasspack melted your upper control arm bushing and this was your fix cause you can't afford $40 for a new muffler...
  • J
    Jeepergeo reacted to JPNinPA's post in the thread You might be a redneck if ........ with Like Like.
    You might be-a redneck if you have enough OE parts from upgrades to rebuild the stock jeep Never look down on anyone unless you are...
  • J
    You might be a redneck if your tire inflation is comprised of lighter fluid and a match Never look down on anyone unless you are...
  • J
    You might be a redneck if you change rear gear oil more often than engine oil. Never look down on anyone unless you are helping them...
  • J
    Jeepergeo replied to the thread Lawn woes.
    I got rid of my last lawn grass maybe 12 years ago and have zero regrets and a lot more time for other things. We put down shreaded...
  • J
    Jeepergeo replied to the thread Another noise from under my TJ.
    I could see maybe left to right engine roll with worn mounts. Forward and backward would surprise me. Check that fan and serpintine...
  • JPNinPA
    JPNinPA replied to the thread Lawn woes.
    Some yards are like this Mine has other junk weeds. It was near perfect last fall. IDK I don’t need weed free perfect. I just wanted...
  • TerryMason
    TerryMason replied to the thread Lawn woes.
    Here's my front lawn. I put down artificial grass a couple of years ago and never looked back. Saves me about 3 minutes of mowing a...
  • TerryMason
    I pulled the rear driveshaft to replace the ujoints, but I'm seeing some play in it. This is a Cherokee front driveshaft that I had cut...
  • M
    mark sr replied to the thread Lawn woes.
    I have mountain property and barely any soil under the sod. Took me over 20 yrs to get it all green and I have no aspirations of a weed...
  • superj
    superj reacted to JPNinPA's post in the thread The OFFICIAL joke thread? with Haha Haha.
    Why did Beethoven get rid of his chickens? All they ever said was, “Bach, Bach, Bach!” Never look down on anyone unless you are...
  • superj
    superj replied to the thread Lawn woes.
    i don't have to worry about that kind of stuff here along the coast. my yard is sand so all i get it weeds and junk. it would be super...
  • superj
    superj replied to the thread Window regulator.
    Holy cow thats a bunch of money.
  • JPNinPA
    JPNinPA replied to the thread Dirty body pic.
    I’m hard pressed to blame fuel for a TB issue. Fuel doesn’t flow through there. Air from the valve train does and the lower crank case...
