How difficult to r & r blower motor TJ ?
Ru you replacing the the heater blower motor or the resistor?
The heater blower. i used to be able to tap it with a hammer and it would start working but my quick fix does not work any more so I found a used one and am going to attempt to swap it out. I am guessing it is the motor that is bad.
Hope this helps you out.
UUhhmm, That illustration is for a CJ.. Here's the one for the TJ.
REMOVAL
  1. Remove the battery from the battery tray. Refer to Battery for the procedures.
  2. Remove the three screws securing the Powertrain Control Module (PCM) to the mounting bracket on the engine compartment side of the dash panel. Move the PCM away from the blower motor opening in the dash panel Blower Motor Remove/Install
  3. Unplug the blower motor wiring connector.
  4. Remove the three blower motor and wheel assembly mounting screws.
  5. Remove the blower motor and wheel from the heater-A/C housing.
  6. Remove the blower motor wheel retainer clip and remove the wheel from the blower motor shaft
INSTALLATION
  1. Install the blower motor and wheel into the heater-A/C housing.
  2. Install and tighten the three blower motor mounting screws.
  3. Connect the blower motor wiring connector.
  4. Install the PCM to the mounting bracket with three screws.
  5. Install the battery in the battery tray.
I agree with you.I went and looked at my tj and yours is correct..Time to mail Haynes and have them some corrections.
Your welcome. I make mistakes too so be careful when you read my post.
Looks like you have the info you need so this is just an FYI... I thought my TJ had the blower motor inside and I finally had a look at it. They must have made a change sometime. My 05 has the motor hanging down above the passenger side. It does not go throught the firewall. Looks like you just turn the assy to remove it (there are plastic bayonet type lugs on it). So there are two TJ blower motor styles (or maybe even more). Best of luck - John
thanks steel, i was wondering the same exact question! my went out too! I love Jeepz! someone always knows! i was really hoping i didnt have to take the dash out! i hate interior!
