cmmartin86
I need help/ideas. I have a 5-speed, 4cyl, 2.5L Wrangler TJ (01), and I installed a Eaton m45 Supercharger on it. I am having a consistent hesitation every time -- 100% of the time -- I accelerate and hit 2000RPM. I can push through it, and the jeep will run perfectly fine again. It is solely at 2000RPM that this hesitation occurs. Also, the smell of fuel accompanies this hesitation. P0301 Cylinder 1 misfire code is thrown.
I have replaced just about everything I can think of, and I'm running out of things to test. I don't really want to take it in because I know they will charge a lot, but if that's the last resort.
List of replaced:
Crankshaft Sensor
TPS
02 sensors
IAC
Radiator
Checked/cleaned fuel pump and filter
IAT
Air Filter
Ignition Coil
Spark Plugs and Wires
Cap and Rotor
Checked exhaust valve rotation
Compression Test
New Fuel Injectors
Checked Fuel Pressure (50 psi) -- no leaks
Vacuum Pressure (no leaks)
Ran seafoam through
Clock Spring (yes it's real)
Drained gas tank and have only used Premium
I'm considering changing the distributor and ECU next, but would rather find the problem before dropping a couple hundred on these.
Suggestions?
Thanks
List of replaced:
Crankshaft Sensor
TPS
02 sensors
IAC
Radiator
IAT
Air Filter
Ignition Coil
Cap and Rotor
Compression Test
New Fuel Injectors
Ran seafoam through
Suggestions?
Thanks
