Hey Utah, I know this thread is a bit aged, but did the fuel pump and pump assembly end up being the problem? My '97's been throwing the same code for a long, long time and I haven't had a mechanic able to track it down.
Thx
After everything I have done still never got to tge bottom of this. When the money comes available going to pull the head and have it rebuilt. Thinking it might be the exhaust valve springs as one article I read suggested.
Michael, what narrowed it down to the crank sensor even a year ago? Is this an easy repair?
It is not difficult.
The symptoms of a failing crank sensor CPK is engine randomly not starting or shutting off while driving. When it fails the engine just doesn't start.
The symptom of a bad CPS is poor gas mileage, rough running, misfires or engine not starting.
Hmmm, not sure if this is my problem then. The milage is horrible 11 -12, but I do have 190k on the engine so wonder if it's simply age. Runs great, smooth, never hesitates and has never stalled. As far as starting I do have to turn the key and wait about 5 seconds then she cranks over fine. If I don't wait and crank it right away it's harder to start. Misfires, really none to speak of if you listen, but watching the needle at idle you can see it just slightly bump. Engine light stays on forever unless it's reset then after I hit 65mph it comes on solid again. I'm still thinking valve springs as I've read, but don't want to go there if I can help it. If I did the valve springs can I just swap them out with OEM's without doing a complete rebuild of the head?
Watching which needle? Battery?
Clean your throttle body and IAC. Last clean the valves and cylinders. There is a method of pouring slowly about a1/2 cup of water into the TB when the engine is not and running. Manually keeping the idle up so it doesn't stall drizzle the water in over 2min. Once finished shut the engine off and for 15 min. Then start the engine and run at 2500-3000 rpm for a few min. It is ok to drive it this way. Take the RPMs above 3300 occasionally so the valves have a chance to rotate.
Also run fuel injector cleaner in your tank.
For the check engine light. What year jeep? You could do the key dance ( off to on, and off three times ending in the on position) and read the codes in the odometer or go to AZ or adv and borrow their clad reader. Post up the codes. Well give direction fro there.
