Hi,
I have an 87 XJ 4.0L FI with 113k on it. had to replace the alternator this summer because oil blew into it from my leak. I am putting in a quart every 1000 miles or so and I'm not terribly worried about it. Put in a new battery a week and 1/2 ago, beacuse old one was getting weak.
Had 2 days in a row that were below 0 for the high temp and on the second day, the ignition wouldn't switch over to lock, but all was shut off. It stopped somewhere between lock & acc, so since the switch has been broken since purchase, I wasn't terribly worried about it. (Broken meaning you didn't need a key to start, run & drive it, thank God for the Club, LOL!)
This morning, went out to fire her up, and all accs have power, radio comes on, internal lights, etc, but turn to start and click. Try again, click. Doesn't even try to crank.
I am thinking that this is probably indicative of needing to buy a new ignition switch, don't know if I should get that or an ignition lock cylinder or both.
The only other thing that I can think of is the neutral safety switch, though that would make less sense since the XJ was probably telling me something I ignored when the ignition wouldn't go all the way into lock.
Does this thought process make sense? Any other ideas, suggestions, etc, before I go to the parts store later this pm? Anything I can try that would narrow it down, if that needs to happen?
Thanks!
Alex
Thanks!
Alex
