highlandwarrior
First post here. I have gotten alot of great info from this forum. Two questions:
1. How do you remove the "stick" from the tower assembly?
2. Just bought a used AX5 transmission for a swap out. The transmission I got does not have the cone? assembly that holds the fork for the clutch slave. I swapped out the front bearing plate from the old transmission, bolted up with no problem.. Will this be OK? also does anyone have a trick to installing a new front bearing retainer seal without having to shell out $50 for the special tool? I tried using the seal from the replacement in the old plate but the shaft does not turn freely as it did before????
