I am going to buy the Daystar. They are total replacement body mounts not just spacers that you put on top of you existing mount. Daystar says that they keep the body aligned properly and are susposto improve handling also. I would go with this type because the other design can shift and move not good. That's just my opinion. Thanks for the compliment on my rig its not a Rubicon though.
It's possibly to go with a flatter belly skid (like Teraflex) after the 1" body lift, but it's best to do a 1" motor mount lift at the same time. This way your drivetrain remains level and you don't have to modify the fan shroud.I've been reading some of the posts about the 1" body lift and was wondering. Is there any shifter problems with an automatic 99TJ? Other than trimming the fan shroud is there any other mods that would need to be done before the install? Also, what all has to be done in order to get a more flush mounted belly skid at the T-Case?
Some guys have told me when you do a body lift, you are able to get more ground clearance from the stock belly skid because you are able to raise it up But I have no idea.
jonsolbe, loosen your transmission mount bolts slightly and take the jeep for a slow speed spin around the block. Retighten and see if that doesn't help with your squeek.
As for the 2" BB, it's a great option for a budget. One additional item that may be needed is the cam bolts for the axle end of the front lower control arms. Early TJ's came with them, later TJ's did not. This allows for precise caster adjustment after a lift. I run them all the way out for a 2" BB, pushing the bottom of the front axle as far forward as possible. This corrects the caster and pinion angle, removing vibrations after the BB install.
Thanks for the kind words, I just enjoy passing along all the seemingly worthless gee-whiz information that has crept in over the years.
Hey guys,
I'm jst wondering why you would want to install the motor mount lift. How does a body lift affect your driveline angle so that you sould want to raise your engine to fix it??? I'm so confused...:???:
