TJ speaker wiring
Had to have my gals 93 YJ towed home this weekend, I think it has a bad slave cylinder (see previous post). The jeep has the dreaded Pugeot trans, I know the ax15 should be with this year but my gal fried the engine a few years ago and had it replaced. I think the mechanic replaced the engine and trans to make his job easier. Instead of just replacing the slave cylinder after I crack this egg open I want to replace the disc, pressure plate, pilot and slave so I do not have to go thru this again for a while. With out running the risk of sounding ignorant, what is the best course of action for ordering a replacement kit??? Although it is a 93 YJ I dont know if the spline count would be the same for the Pugeot trans shaft. Should I crack and count the spline number or can anyone tell me if these two transmissions are compatable. Thanks, Frank
