90Xjay
Does this happen to your 4.0?
Once in awhile, when I start it up, the engine revs by itself to about 2700 rpm and stays there for a few seconds, nothing I can do, besides cut the ignition helps. I can lift up on the throttle pedal from underneath and nothing. Its like a hung throttle but only last about 6 seconds. STill not good for just starting and running high revs. It done it about 3 times the other day. I am going to take some good throttle body cleaner and spray and clean all of the carbon out of the throttle bore and plate. I have checked all cables and they are loose and free. I dunno, less mabey I have a ICS (idle control speed) motor or TPS Throttle position sensor, but usually they cause the motor to not idle high enough, and I have no check lights on either. I was thinking about posting this elsewhere also cause this is not just an XJ issue, it has more to do with the injected 4.0
Thanks
90
Thanks
90
