Does it have to be an AMC 360? I have a 304 in my 5, and it's more than enough power. And, depending on where you are located, I have another 304 I don't need. Are you anywhere near Chicago?
AMC Remanufactured Motor (V8, 304 CID) | Rebuild Engine For 1972 - 1979 AMC Try this place i know they have 360 i just purchased a 304 from them and was very pleased with the rebuilt engine when i got it. the link actually gets you a number to a company in Spokane Washington.. hope this helps
Hi Guys new to the forum. I own a 76 CJ5 which I am planning to put a 283 in but my buddy has a 82 CJ5 in which he is going to swap out the 4.2Litre for an AMC 401. Does anyone know the specs on the bolts (size and grade) for the bolts on the flywheel and clutch assembly?
screech.owl
The 401 is externally balanced. A 6 cyl flywheel will bolt on but the motor will vibrate it's rods off unless you get the flywheel matched.
