47000
Are you sure that it is the exhaust hitting the front drive shaft? I would imagine the easiest place to start is to climb underneath and pull on everything. See if you can actually get the exhaust to bang into anything, and if so find out what is broken. The usual culprit is a broken exhaust hanger which is under $10 and easy to do.
Good luck,
Terry
