geronimo_e
I had recently changed my front R&P from a 3.07 to a 4.11 and this weekend I swaped the rear ones, got a donor from a junkyard '86 4 cyl cherokee, everithing went very very smooth exept for the fact that I'm a little worried about tha fact that I might have left the carrier case to tight . I say this becouse the case did not go in very easy, it took a few taps with a hammer (not that hard :wink: ) and pushed it in with the race retainers, but still you cant just take it out with your hand. What are the main simptoms that would indicate that it is way to tight!!??? will it eventually wear and loosen up (hope sow :twisted: ):?: ... if the it does not show any foults at all and works fine, can I install a ez-locker on the rear (its a Dana 35) without having to remove the case again (couse I dont have the proper removal tool)??? what is the proper method to remove the case anyway :? ... Thanks a lot... any good lies that would ease my worries would be great....
