amc v-8 engines are exterally balanced, which means the flywheel/flex plate has counterweights built into it as part of the crankshaft counterbalancing system. you will need an amc360 flywheel and the entire crankshaft/flywheel assembly needs to be balanced as a unit. good luck, john
