I have an 83 CJ-7 with a 401 V8. When I drive it and then shut it down right away and the temp climbs to ~220 or 230 because the fan is no longer turning, it becomes almost impossible to start. I'll turn the key, and the engine will hardly turn over. I have to let it cool down to ~150 before I can get going again. It makes the same kind of sound you'd hear if the battery was dead, and I was trying to start it. The bat. gauge reads 12 v though.
Is this a choke problem with the butterfly valve occasionally staying in the closed position? It also runs rough in the morning until it's heated up fully. It'll lose power when I try to accelerate. Once it hits running temp though, it's fine.
I really appreciate any advice you might have. Thanks
Joe
Joe
