Ok.. I needed new front pads. Not a big deal,. Well got the new pads in and discovered my bleeder valves were stuck to point that i stripped both of them, so i just decided to get new calipers. Put everything back together, Bleed all 4 lines. No air, new fluid coming from each line, BUT NO PRESSURE ON PEDAL when running?? When the jeep is not running it acts normal, pump pump tight. When running nothing! any ideas?? did i get a bad caliper??
