I'm not quite following your description of the problem, hard to deduce what bushing you're referring to. Are you able to post pics?
If it worked before coming loose and nothing else has changed, sounds like it's shot. If you had the body lift prior to the problem and it worked fine, sounds like something on the shaft is broken.
