How do I check Pinion Bearing Pre-Load?
ad5at
Need to put in a new Pinion Seal on my 99 TJ, (Dana 35), and the Tech. manual says to check bearing preload before removing pinion nut. Looks like if I just install a new crush collar instead of trying to re-use the old one, what difference would this make?
Has anyone else done this? I know that as many leaking Dana 35`s that are out there, surely someone has. I just know that as much trouble as 35`s have with pinion bearings , the torque on this must be precise.
Thanks!
