I have a Jeep Wrangler YJ and while it is in park or while in reverse it is starting on it's own.
There are no keys in the ignition, and i do not have auto start for this vehicle.
Thank you in advance for any help
I found this recall on my YJ it may be what you have going on also
[FONT=Verdana, Arial, Helvetica, sans-serif]
Recall date: [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Not reported [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Units potentially affected: [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
100,000[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
NHTSA campaign number: [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
93V083000[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Defective part or component: [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
ELECTRICAL SYSTEM:IGNITION:SWITCH
Description: [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
SALT CORROSION PRODUCTS BETWEEN THE STARTER SOLENOID WIRE AND THE ADJACENT BATTERY FEED IN THE BULKHEAD CONNECTOR MAY SHORT THESE CONNECTIONS, CAUSING THE CIRCUIT TO BYPASS THE IGNITION KEY CONTROL OF THE STARTER MOTOR SOLENOID. THE CAR CAN START WITHOUT THE STARTER SEQUENCE BEING INITIATED BY THE IGNITION KEY IN THE IGNITION LOCK. THE UNINTENDED START OF A VEHICLE WITH A MANUALTRANSMISSION LEFT IN A DRIVE GEAR CAN RESULT IN A RUNAWAY VEHICLE. THE STARTER SOLENOID WIRING WILL BE SEPARATED FROM THE BATTERY FEED WIRE BY RELOCATING IT WITHIN THE BULKHEAD CONNECTOR ON AFFECTED VEHICLES.[/FONT]Hope it helps
