I got these (3) led blue lights for the inside of my jeep. It says to hook it up to a 12v source... im gonna do my head lights because when its dark i would want them on... the only thing is how do i do that!?
Yes you can, but it's still a good idea to have it on its own switch so you can turn them off while having the other device on. I would personally put them on their own power. There might be times you want your headlights, or fog lights, on without the interior LED. There might be times when you want the interior LED on without the headlights or foglights. It's no tough deal to wire it up to its own power supply. In fact, it will probably be easier and faster
Basically, find a 12v source for the power, and like Snitty said, just hook up a simple switch in-line to control the on/off..........really basic stuff......switches (buttons, toggles, lighted toggles, etc.) are readily available from any car parts store, radio shack, walmart - just about anywhere. Snitty's right......you need to have it switchable just for the variety. If you can get 'er hooked up to a power source, the switching part is easy.
You prolly want to pick another color, as law enforcement frowns upon the use of blue lights for non-cop car use ! It's illegal here, but maybe just another reason to pull you over there.
Not a problem on the interior, so long as they cannot be seen directly from the front of the vehicle. Here in Kansas, law states only two colors of lights can be seen from the front of a vehicle, yellow/amber and clear. As far as rear-facing lights, any color goes except clear, except for reverse lights, which by law must be clear.
I ran a 50 amp, 4gauge wire from my battery to the inside of my cab where I created a power access point. from that, I run my accessories. It is basically a positive battery terminal movied into the jeep. I used to run all my accessories to the battery, and it started to get cluttered, having everything O-ringed onto a battery terminal. Either way though, regardless of what I use for my power source, I run a wire from the source to an inline fuse holder (available at any auto parts store for a buck or two) to a switch (sometimes a relay) to the accessory. Then a wire from the accessory to ground. Turn on the switch, enjoy the fun.
go to autozone (or similar) and buy:
-14 gauge red wire (20 feet is way more than enough)
-14 gauge black wire (3 feet should easily do it)
-fuse holder with fuse (whatever size the device suggests)
-assorted connecters (ring terminals, spade connectors, etc.)
-wire ties/tape
-switch
-any tools you might not yet have
Disconnect the negative battery terminal
Connect red wire to the positive battery terminal
One to two feet from the battery, cut the red wire and hook it to one side of the fuse holder. This should be place where you can secure it to something so it doesn't flop around
Connect loose red wire to the other side of the fuse holder
Run loose red wire from the fuse holder into the cab
Decide where you want to put a switch
Mount it
Cut red wire off when it reaches the switch and hook it to the "12v" terminal
Hook loose red wire to the other terminal of the switch
Run loose red wire to LED lights
Hook red wire to "12v" on LED lights
Run black wire from "ground" on LED lights to any chassis ground (usually any screw that goes into the body)
Connect the negative battery terminal
Make sure the fuse is in the holder
Turn on the switch
If the lights do not come on, go through the directions again.
Hey, Snitty, you dont mind me calling for detailed instructions like these for installing a SYE, new shaft, SOA, winch, new front bumper, new rear bumper with Tire carrier, regearing to 4.56 andinstalling 2 pairs of auxiliary lights, right? I want it step by step (but make sure to include pictures this time!)... HAHAHAHA!!!!
I'm right on top of that... I'll make them into animated GIF format, and give you individual instructions for your right and and left hand, so you don't get confused and do something backwards
