my yj wont start
slo-wrench44
i was working on sand blasing the battery tray on my toy, when i was done and had everything out i thought i might as well clean up the corrosion on that lil box directly under the 4x4 light vacume switch. after i was done it wouldnt start on its own. i started it with a screwdriver on the starter but it wont turn over with the key. i might have wired it wrong. does anyone know how that box is wired. it has letters on each terminal. the top two from left to right are f and batt. next ones down are i and sol then g and i. i know all the ones with ring terminals are supposed to go on the batt but what are the others? i kinda need it for work on tuesday so any help is greatly appreciated. thanks guys and gals.
i really need help here any advice is welcome. i think it is a soleniod but it isnt the starter 's
Batt: battery
F: feild (alternator)
I: ignition (to the switch)
G: ground (on firewall or engine block)
Sol: Starter solenoid
Hope that helps. I have a detailed wiring schematic in pdf format if you need anymore info. What year is this Jeep?
