need drivers side door handle ASAP
Greencuke
i went to start my jeep this morning, and the drivers side door woudn't open, so i went in throught the passesner side. being the retard that i am, i tried to sholder the door open, and snapped off the inside door handle. where do i get one asap? i can't seem to use my door![addsig]
1046377
Junkyard or dealer are about the only options.[addsig]
1046394
I've broken both of mine in the past. I've used a piece of metal banding that's used to tie things down on skids. I assume the outer rubber is ok, just the metal inside ripped at one of the holes. If you cut it just a bit longer, it'll be stronger than before.
Mike[addsig]
1046395
yeah you could probably do a home depot run and land yourself a new stainless steel handle... home made style![addsig]
