I have a little problem with either the gas pump or an electrical connection. The gas doesn’t reach the motor neither the fuel filter. I disconnected the fuel filter and turn on the key to see if some gas would come out, but nothing. It started few months ago. I had to turn the key several time to start the engine and was able to turned it off and restart right away w/o problem. I also had a problem with the battery cable going to the negative post. The connection was bad because of corrosion and the pump was not getting power all the time. I thaw it was the problem because after cleaning the corrosion, it stop sputtering but was still a little hard to start cold. How come I am loosing pressure in the gas line if the jeep seats for few days. Is there a way to test the pump? The access to the electrical there is pretty tight. Thank you for your help
