No pressure/resistance on clutch
Charlie Stewart
Driving the other day and I go to shift gear and there is no resistance on the clutch pedal so I had to pretty much power shift all the way home. this has happened before but the problem went away after about a few weeks or so of driving like that
Not only would I follow Terry's advice...But trace out your clutch linkage, may have become loose and is not properly engaging the clutch fork at the trans?
and remote resivourSounds like a master cylinder/slave cylinder bleed time. It takes two people usually, and sometimes is tricky to do. Ideally a pressure bleeder is the way to go. It has a lid that fits your master cylinder and as you open the petcock on the slave cylinder (bell housing location) it forces brake fluid through the system alleviating and bubbles that cause the lack of 'push-feel'. Otherwise, doing it with two people is the only alternative. It's just about the same as bleeding brakes in methodology.
