JJs 88 Wrangler
Hello All,
I have an 88 Wrangler with a 4.2. My oil pressure needle staring pinning past 80 psi when the engine is running so I bought a new sending unit. Now the needle stays at 80 psi while running. Do you think by changing the oil pressure switch will fix my issue? The engine is a rebuild and only has 6000 miles on it. The gauge used to work perfectly up until a few months ago.
Thank You in advance for any suggestions.
JJ
JJ
