dookie.kim
So I'm new to the Jeep community and relied too much on a friend of mine to help me fix up a 94 YJ. I ended up having to go solo and ran in to a big problem that could really make or break my bank.
I bought a B&M Short shifter only to find out that it doesn't fit my transmission. I had to assume that the transmission was replaced prior to me buying the jeep. In order to see if the new transmission even fit, I had to remove the 4x4 transmission (which was a huge pain in the butt.) because there was a plate attached to the 4x4 shifter covering the transmission mount. It's a little hard to explain being new to Jeeps so let me get to the point.
I re-installed the old transmission and 4x4 and now I can't start from 1st gear. 2nd is a little ok. I haven't tried 3rd. I can reverse fine. It feels like when I give it gas in 1st, it jerks forward like there is no gas, when the tank is full. My, so reliable buddy, says that it sounds like its stuck in 4x4. But I have moved the 4x4 through all of its settings from 2h and so forth but it jerks the same throughout. Also, in any drive gears, when the wheel is turned all the way it starts wobbling extremely bad like its trying to straighten itself out.
Any ideas??? You could really be saving my life!
Ty in advance!
Ty in advance!
