Rebuild my T-5 transmission?
86CJ7
Well, the time has come where my transmission is starting to go... I'd like to stay with a five-speed so... do I rebuild the stock T-5 or do I go with the World Class T-5 or NV3550? Other ideas? Any advise on the clutch?[addsig]
1045110
if you can afford to go with the NV3550. of course it also depends on the type of driving you will be doing.If the jeep is nothing more then a transportation to work and the grocary store,then keep the stock trans.[addsig]
1045540
Thanks for the reply! This Jeep is my daily driver and it doesn't see much more than a dirt road or a little mud. Definately not into rock crawling, so I guess an expensive transmission isn't what I need. Though everything I've ever read about the stock T-5 suggests it isn't worth rebuilding. My thinking was always, if I was going to spend that kind of cash I might as well put it towards a better quality transmission than rebuild a weak one. As a light duty Jeep, I guess I'll be okay with rebuilding the stock T-5...? [addsig]
