originalrider41
When pulling someone out how bad is jerking the strap? Does it damage the frame, bumper, whatever your attached to when done reasonable? Does a recovery strap vs a tow strap really make that much of a difference?
Most people are familiar with tow straps when it comes to pulling your vehicle out of a trouble location and onto safer grounds, by which time hopefully a tow truck arrives to help you. One of the primary reasons to not choose tow straps is associated with the hooks attached on either ends of the strap. Imaging the following scenario -
Your vehicle breaks down and you manage to stop at the side of the highway out of harms way. After this, you either contact a friend living nearby or if you're lucky enough, a stranger driving by offers to help you out. You then proceed to take out your trusty tow strap from the trunk of your car and attach both hooks to the front of your vehicle and the back of the stranger's vehicle. The stranger then begins to pull you and your car, steadily at first. So far so good, you say to yourself. You're pulled back onto the road and both of you are traveling along at a sensible and constant speed. Without warning, either the strap itself breaks due to some defect in the hardware or because it was improperly secured. The hook (made out of metal) will go flying at speeds sometimes in excess of 60mph.
As you can see, it may not be very safe to use tow straps. There have been cases where people have been seriously injured or even killed as a result of incidents much like that described above. Tow straps do not stretch and won't have much give.
Now, in the case of recovery straps, they do not have hooks at all on the ends. Instead, they are just a long flat length of nylon with sewn loops on either ends. Also they stretch so they actually behave like a rubber band, returning to its normal length when there is no tension. This is definitely a much safer option. There are recovery straps in a range of length and width. You can get straps from 20 feet long all the way up 40 feet long. Widths can vary from 2 inches up to 6 inches. The width of the strap affects its elasticity (or ability to stretch basically). The wider the strap, the less elastic it becomes. Generally speaking, as you go up in the width, the heavier the vehicle you can tow - each inch in the width allows you to pull approximately an additional 10,000 lb
IMO a tow strap will not stretch much, designed more for moving a load for a distance. A recovery strap will stretch, hence being used during a 'recovery'.
Do not jerk a tow strap, they're not designed to stretch and you are more likely to break/damage parts. Recovery straps are designed to be jerked after putting a little slack in the strap, the rebound actually exerts more force on the stuck vehicle and aids in the recovery.
