taymonxuytuyet
parts for sale
Hi, I bought my 95' YJ two months ago and since then I got hooked. Now I want to go for SOA and have a few questions to ask the experts "out there" (and thank you in advance, guys!!!).
I hear about the angle of the spring perch need to be line up precisely, how can I do it ( measure the angle and line up the spring perch) ? Does it has anuthing to do with the ring and pinion of the differential (front and rear) ?
Can I do the SOA with out changing the SYE and CV shaft ?
Beside a dropped Pitman arm, do I have to do anything else with the steering system ? ( just installed a new stablelizer)
In the worst scenerio, I can't afford the SOA, can I just do the block (2") for the front and the rear on the YJ while saving up for the SOA kit? (As you already know, the block kit is only $25 per axle!)
Again, any answer will very appreciated,
Quang.
P.S. by the way, I am located in central Ohio, I have been asked around the 4x4 shop, no one is willing to do the SOA conversion, even thought I insist that I will release them from any liability.
Quang.
