Soft top not fitting
I noted your pins are on the outside and mine are on the inside. Shouldn't cause the issue your having but a difference. My top and frame is Stock. Your windows look new and material is different.
Mine is stock. Nothing new. I just try to keep it maintained. Xcept I can't keep this damn AZ dust off of anything! Mine is an '06 unlimited with the sun rider.
Had the same problem on mine up here in ontario. Dont know if the old owner ever even put the top up. I found that makeing sure the sunrider slides were totaly locked back helped. I also ended up doing the pins then the front clips then the rear sail pannels. Hope it helps.
I just took it down again. Will have to go up on sat. I'll check the sliders on the sunrider mechanism when I try it. Thanks for the advice.
Took almost a quarter of the effort to put the top back up as it did when I was in Arizona. Must've had something to do with the Arizona weather.
