1067445
With in the last 5 months I've replaced the starter, battery and cables on my gals 93yj and I am still having starting problems. All connections are grounded properly and have clean corrosion free sufaces. I've noticed a starter relay in the wiring schematic (Haynes service book) and am curious if this could be the culprit. The only other ideas I have is a bad ignition switch or the rebuilt starter I installed has failed. Any thoughts would be greatly appreciated or her baby is going to the Stealership for diagnosis. Is there any way I can sort of jump-start the starter motor (screw driver across the pos/neg terminals on starter) to see if the starter is in fact operating properly. Thanks Frank[addsig]
