(1977 CJ5) I have been reading all the previous posts regarding 'wandering'. My steering gear box is leaking fluid so i know it needs rebuilt or at least new seals. I have a very slight tie rod slip. Replacing which of these two should give me more results? I will do both but which one is going to do the most good to correct the 'wandering'?Also have a question about lift. It appears I have stock leaf springs. I don't really want it any higher of the ground. Running 33x12.50s. What is the smallest amount of lift that I can run the same wheel and tire package? Should I switch to coil springs? Are coils even possible? Will any of this help correct the steering issues?Thanks,Jerms
