TJ or YJ? I wouldn't recommend it for a TJ :shock:cewtwo said:I used a 3.5" BDS lift and am running 33" tires. I completely removed the sway bar over two years ago.
Bounty__Hunter said:We did, but the original poster of this thread has a TJ, and cewtwo was recommending deepsixing the swaybar.
I did notice that I had alot more articulation but I have a long arm kit on the jeep so that could be the case. there is little to no improvment to the off-roading when I took them off since I had rear discos already. Driving on the street is fun...I HAVE to slow down to take turns but as I have said I am getting older,wiser and lazier (is that a word?) so I s**t cannned them a while ago. For my two cents they were worthless.Bounty__Hunter said:I've always read that removing the rear swaybar on a TJ gains you no articulation or other performance enhancement. True in your case?
