Aaron Myers
Hi everyone, I'm in a jam, I swapped out the stock tail lights on my 95 yj for round LED's. I am convinced I didn't wire it right though because I have no brake lights (only running lights), when left signal is on there is no change and when right signal is on the left light goes out. When I turn on the hazards the left light blinks.
I had three wires from the new lights, on the drivers side it is grounded to the body, and then to the green and white wires of the stock wiring harness. On the passenger side the body ground and a light wire go to the green wire and the white wire is connected. The ground wire is out of play from the light itself. This is the only combination that an all day wire project found any success from, but like I said I only have running lights! I replaced the flasher with an EL12 (which I was told I would need to do) but that did nothing for me.
This is my daily driver and I need to get this figured out quick before I get a ticket or a rice burner to the rear end! Thanks!!
