transfercase swap
canexel
Hi yall,second time here, posted further down about trans or transfercase noise,if I swap out the d-300,what other transfercase is a direct swap? thanks again.Jeeps+Mud=Fun.
1043718
A Dana 300 is a direct swap
but there are 2 different ones. The '80-'81's are shorter(the rear output) then the '82-'86.[addsig]
1043788
The D300 becomes a big POS after you add stuff like the tera low kit to it
Nothing else will be a direct swap unless you put in another 300, an atlas ii might be a simple swap because you can order it with the input shaft you want. Advance Adaptors should be able to sell you an adaptor for your application
1043920
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE>The D300 becomes a big POS after you add stuff like the tera low kit to it
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Which is why i got an Atlas...
