i know this is probably a stupid question.... but when im in 4wd and i try to make hard tuns....exe. a uturn the wheel wants to jerk back straight and i was just wondering if that was normal?
i've expeiences this on soft surfaces too, sometimes the U-joints on the axle will bind at a high angle, try turning the wheel back toward center just a tad.... see if it helps.
well i was making a u turn on a hard road it was at the end of the trail i was on..... so i was turning around to go back to where i came from so i could get back to where i left my buddy causehe was scared to ride with me on a paticular stretch of this trail.
it is normal if you are on a hard surface... and if you are on loose surfaces, it can be from the ujoint bind... both are normal... i refrain from cranking the wheel all the way when in 4wd
