1049966
Hmm well ok...n00b questions eh....
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE>What would be a good gear ratio for the rear end that is good off road but is good on the road?</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
It depends on how big your going to go with tires...up to 31inch tall tires the gears you have (3.07) will work fine for on road and off...going bigger you will want some lower gears to maintain good highway speeds
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE>What kind?</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
This would be an opinion...honestly it depends on how much you want to spend...keep in mind that you get what you pay for.  Most of the time just regular OEM gears will do fine.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE>Would it be a DIY project?</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Negative....gear changes should best be left to a pro or a shop...while it is possible to do them yourself...I don't think you would want to because if something in the gears (spacing, alignment, tooth contact, ect) is not setup just right...the gears will eat each other up or even worse the axle may just seize up and grenade...possibly taking your tcase and transmission with it.  That would be bad
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font class="pn-sub">Quote:</font><HR></TD></TR><TR><TD><FONT class="pn-sub"><BLOCKQUOTE> Can somebody tell me what a gear ratio is or what it means? </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Well hmm yeah I guess I can...a gear ratio is usually defined as the ratio of one set of rotation objects to another.  In this case that would be your driveshaft  to your rear wheels.  In my jeep I have 4.10 gears...that means for every 4.10 turns of my driveshaft....my rear wheels make 1 revolution.  Of course when you put bigger tires on...that makes your gear ratio change...the bigger tires take more turns of the drivshaft to turn one full revolution.  Generally...since bigger tires are heavier and harder to move...you want a higher gear ratio with them...for instance if I had 35's on my jeep I would probably want at least 4.88 gears to be able to run them effectively.  A good analogy here would be riding a 10 speed bike....on flat stuff or downhill you can run higher gears (lower numbers) to get more speed...but going up a hill you shift to a lower gear to get more torque (larger numbers)...since you need more torque to turn the bigger tires...you want a lower gear (larger number)[addsig]
