theonetruetom
Hi all,
I think I'm running into a fuel pump issue with my ZJ, but I'd like to bounce some ideas off the brain trust and see if I can confirm this.
For the past couple months, when I'm on the freeway (97 ZJ 4.0 2wd) the truck will act like it's losing all engine power. There are no CELs, no codes, and no other indication of problems. It was a momentary stutter that straightened itself out within a half-second. Then it started getting worse. It went from once every 2 weeks or so, to once a week, to once a day, and now today on my way in to work (30 mile commute each way) it started doing it every few minutes. Stop lights are where it happens most, and it's acting like it isn't getting gas at all, or is getting it in surges. If I turn the truck off, and let it sit for a minute or two, the problem goes away (probably crap getting sucked up into the strainer?) but only for a mile or two. The issue hasn't been consistent enough currently to where the jeep won't start and drive, but it is definitely causing some driveability issues for me.
What do you guys think, am I on the right track with the pump?
