TwistedCU
Active member
I ordered a set of disconnects for 4" lift from Rough Country ($49). They came with adapter brackets for the stud type top mount. Well the adapter came with a short bolt and the bracket, and that's all. I used the factory bushings to mount it to the swaybar, as just bolting it would not have worked.
This required longer bolts. No big deal, $0.28 at home depot.
well now the disconnects are too long, and put the swaybar waay up too high so I'm having my neighbor who works in a metal shop cut the center sections down and re-drill them so they are the proper length.
In the meantime, I have tied the bar up out of the way until I get them back and will be driving swaybarless.
anybody else had an issue with this? am I missing something on how to mount it to the swaybar? Seems like RC should have taken this in consideration but they didn't. Probably should have sent the center sections for the smaller set (stock to 3").
Here's a pic of how I mounted them, am I retarded or is this right???
