I change my gear ratio and I have larger tires how do I adjust my speedometer
tf888
I went from stock tires to 33's I also changed my gears how do I adjust my speedometer
Sent from my iPhone using Tapatalk
You need a programmer then just put the new gear ratio in and then for the tires you need the measured height. Not the side wall height.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Sorry not what it says on the sidewall. So if it says 35 but height measures 33.5. You put in 33.5
Thank you where do I get this program
Online. There a few different one. I have the flashpaq
1999 wrangler 33 inch tires
you are going to have to google if that one gets programmed or not. you might end up having to buy a different speedo gear to match the tire size.
Thank you I already ordered one waiting for to come in
I took mine to a Dino shop that specialized in everything tuning. They hooker her up to a computer and read the speeds over a periods of an hour and adjusted it accordingly. I think that is the best route for accuracy, but I know many shops just use a chart to program.
