RE: Re: RE: Re: RE: Front hitch
Your factory engine, brakes, axles, frame, and suspension are going to be happiest with a narrow 33" tire at the most......and that's stretching it. I'd slap the norrowest 32s I could find on the factory rims and be done. You don't need much lift for that. Your Jeep has the "C" type shackles, but you can easily convert to longer standard style shackles for an inch or so of lift. Then you can make a body lift and clear them just fine.
For header ideas, check out the swamp buggy racers. Alot of the classes restrict engines to the F heads or older. Those guys really crank those little engines hard and have lots of good ideas. And yes.....alot of them have the little F-heads header poking right through the hood.
