paging Hi Hood
54cj3b
hey hood do you have a picture of the back side of the 3b grill ?
trying to modify intake scoop on backside of grill to accommodate a bigger radiator for the 4.3
I went out to take a pic but my camera died. I got the batteries charging now so later tonite or manana I will post up if you still need it. Mine appears to have been completely cut off and tabs welded on (it's all real rough) to hold the radiator. Apparently a lot of room was needed for the 302 ford. I am running the same radiator used for the V8 and running electric fan. The shroud has been chopped pretty much OFF.
yeah I want to run the orig radiator for the 4.3 and was thinking of angling it to clear water pump with elect fan seen it done a while back looked good but I forgot to take picts and my grill is buried at the moment
My radiator is not stock. My grill has been butchered to accept the Ford V8. My fan shroud is GONE. I am putting a Willys F134 back in but my fan is attached to my radiator.
got a few from willy on 3b page
Now I only wish I had one of those programs to see if my design will work before I cut it and I want it to look like it was made this way not hacked
