Into the cowl, out to the relay by the battery.. Relay to battery thru a fuse and the switched connection into the cabin by the brake to switch. Switch power to ign circuit fuse behind the glovebox.
You should still have the cowl opening like the tj's do, but if you don't you can always drill a small hole on both sides and cover it with a rubber piece or maybe some rtv silicone.
