Hey , that is great news ! It was the last link in the broken chain , that last switch to be turned on , so to speak , I felt that it was the only place where power was being lost . I'm really happy for you , this is no time for a man to be without his jeep . Hey , sorry to confuse you about the bypas , the bypass I was referring to would be internal in the TCU ( transmission controll unit ) and what that means is if the unit fails , it will still allow the jeep to run. But since it runs through the ASD , so that the jeep cannot be driven with a bad trans controller and cause trans overheating.
The ASD is meant to save our jeep from its own worst enemy , US ! We may try to drive it and burn up a trans since the solinoid won't shift and overheat internally . Sorry I could not address your posts earlier , had to get back to work , but I just had the feeling you would get it running by the time I got home ! You are a way better diagnostic guy than you thought you were !
Brother , you should be darn proud ! Your progress and prognosis will help many should anyone ever encounters this problem . Guys like you make this forum what we are ! Best of all , you did it yourself and owe nothing to the shop !!!! It's a great feeling when you get your own vehicle running yourself ! Go ahead and slam a couple of brewskies and claim your bragging rights ! You earned it ! I say it again , WELCOME TO JEEPZ.com !!!!!! Good job brother !!!! Greg
