1044609
I have a 90, if yours is the same, look up next to your fuel tank on the left side (up high) the double plug is the sending unit plug. If your gauge is working at all, unpluging the connector will make the gauge go all the way up. The colored wire is the same color, all the way to the fuel gauge, the black wire (sometimes blck with a stripe) is the ground. The power runs to most of the gauges (they share power) then to the fuel sending unit, then to ground. If the gauge stays at the bottom, it´s power in (or a dead short), if it goes all the way to the top it´s an open circuit (broken wire,connector,bad sender)if it stops at a half tank or so, it often means the contacts at the back of the gauge (or at a connector) are oxidized or corroded. The amount of current coming out of the gauge, to the sending unit, is really small, a little corrosion will mess things up.[addsig]
