Hi guys,
Wrangler YJ 1989 4.2 carter bbd carb, only a few months old.
I have searched around the web and have found none that will work for me...
Basically it tries to crank but doesnt turn over. Starter is working as it should, battery is fine, carburetor is not that old and in fact i have rebuild it in search for a solution last night. THE ONLY WAY IT TURNS OVER is when poured a little gas in the carb, then of course it dies a few seconds later when the gas is burned up. ANOTHER thing is when i pump the accelerator no fuel is being injected into the carb. I disconnected the line before the filter to see if any gas is coming through but it is dry.
Note:
I changed fuel filter, rebuild carb, checked the float level to 1/4", check for kinks on the fuel line, changed alternator, and belt, and fuel pump was replaced.
It should be getting spark since the car does turn on when gas is in the carb right?
Note:
